lldp.AllocMemFail
Description
Memory for the displayed object could not be allocated which may be due to the system running low on memory. This will result in incorrect operation of the lldp feature.
Remedy
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory.
Severity
Error
Message Text
Memory allocation failed when trying to allocate a %obj% structure of size %size%.
Message Parameters
Name Type
obj String
size uInt32
